I'm using ArcGIS Pro 3.3.1. There are two polygon layers in my map. For both of them, layer blending is set to normal, but they still blend with each other. I want to turn it off! How can I achieve this?
Thank you,Barbara
I've just found out that this only happens if the upper layer has been generated by a buffer gp tool (Multiple Ring Buffer).
I'm using 3.3.1 and I notice it for the first time. Removing and readding the layer or refreshing the view doesn't work.
It was a bug prior to 3.1. In a pinch, try removing and readding the layers if a refresh doesn't work
