Here i have written code for enabling snapping point and line for the existing line.But its not working in my code.Its working for point without any issue. can u help me out in adding new functions or features added to the code.
webmap-->Group Layer-->Feature Layers
on Initialize i am calling the EnableSnapping();
private async void EnableSnapping()
// Ensure all feature layers within the map are loaded
foreach (var layer in mapView.Map.OperationalLayers)
await LoadLayerRecursively(layer);
// Synchronize the snap source collection with the map's operational layers.
_geometryEditor.SnapSettings.SyncSourceSettings();
// Enable snapping on the geometry layer.
_geometryEditor.SnapSettings.IsEnabled = true;
// Optionally, configure snap tolerance and other settings
_geometryEditor.SnapSettings.Tolerance = 10.0; // Adjust tolerance as needed
// Create a list of snap source settings with snapping disabled initially
List<SnapSourceSettingsVM> snapSourceSettingsVMs = new List<SnapSourceSettingsVM>();
// Iterate through the feature layers to set snapping for points and polylines
foreach (var snapSourceSetting in _geometryEditor.SnapSettings.SourceSettings)
if (snapSourceSetting.Source is FeatureLayer featureLayer)
var snapSourceSettingsVM = new SnapSourceSettingsVM(snapSourceSetting) { IsEnabled = false };
snapSourceSettingsVMs.Add(snapSourceSettingsVM);
// Populate lists of snap source settings for point and polyline layers.
var pointSnapSettings = snapSourceSettingsVMs.Where(snapSourceSettingVM => snapSourceSettingVM.GeometryType == GeometryType.Point).ToList();
var polylineSnapSettings = snapSourceSettingsVMs.Where(snapSourceSettingVM => snapSourceSettingVM.GeometryType == GeometryType.Polyline).ToList();
PointSnapSettingsList.ItemsSource = pointSnapSettings;
PolylineSnapSettingsList.ItemsSource = polylineSnapSettings;
// Debug: Print counts of point and polyline snap settings
Debug.WriteLine($"Point Snap Settings Count: {pointSnapSettings.Count}");
Debug.WriteLine($"Polyline Snap Settings Count: {polylineSnapSettings.Count}");
private async Task LoadLayerRecursively(Layer layer)
if (layer is GroupLayer groupLayer)
foreach (var subLayer in groupLayer.Layers)
await LoadLayerRecursively(subLayer);
else if (layer is FeatureLayer featureLayer)
if (featureLayer.LoadStatus != Esri.ArcGISRuntime.LoadStatus.Loaded)
await featureLayer.LoadAsync();
private void EnableAllPolylineSnapSourceButton_Click(object sender, EventArgs e)
foreach (var item in PolylineSnapSettingsList.ItemsSource)
if (item is SnapSourceSettingsVM snapSourceSettingsVM)
snapSourceSettingsVM.IsEnabled = true;
private void EnableAllPointSnapSourceButton_Click(object sender, EventArgs e)
foreach (var item in PointSnapSettingsList.ItemsSource)
public class SnapSourceSettingsVM : INotifyPropertyChanged
public SnapSourceSettings SnapSourceSettings { get; set; }
public SnapSourceSettingsVM(SnapSourceSettings snapSourceSettings)
SnapSourceSettings = snapSourceSettings;
if (snapSourceSettings.Source is FeatureLayer featureLayer && featureLayer.FeatureTable != null)
Name = featureLayer.Name;
GeometryType = featureLayer.FeatureTable.GeometryType;
IsEnabled = snapSourceSettings.IsEnabled;
private string _name;
public string Name
get => _name;
set
_name = value;
OnPropertyChanged();
private bool _isEnabled;
public bool IsEnabled
get => _isEnabled;
set
_isEnabled = value;
SnapSourceSettings.IsEnabled = value;
public GeometryType GeometryType { get; set; }
public event PropertyChangedEventHandler PropertyChanged;
protected virtual void OnPropertyChanged([CallerMemberName] string propertyName = null)
PropertyChanged?.Invoke(this, new PropertyChangedEventArgs(propertyName));
