// Modif erwan.caradec 03/11/2011 // Remove application error "499 - Unauthorized access" when a secured service can't be loaded and remove the layer from the map // old lines : //#833 var errorMessage:String = event.layer.name + " layer failed to load: " + makeHTMLSafe(buildFaultMessage(event.fault)); //#834 AppEvent.showError(errorMessage); // new lines : if (event.fault.faultCode != "499") { var errorMessage:String = event.layer.name + " layer failed to load: " + makeHTMLSafe(buildFaultMessage(event.fault)); AppEvent.showError(errorMessage); } else { map.removeLayer(event.layer); } // fin des modifs
