Hi all,
I am trying to update and republish an existing survey after adding four questions. The data type for all is a string. There are two select one questions and two text questions. When I click publish it just loads and loads but does not ever publish (see screenshot for where it gets stuck). The only way to exit is to close Connect. I have waited a long time, closed and tried again many times and even tried on somebody else's computer with no luck. I also deleted the survey off my device, redownloaded it and made the changes again. This survey has been republished several times before with no issues. There is a lot of existing data which is connected to a dashboard so I cannot start again from scratch with this survey.
I know this is a problem that happens when the survey form is moved to a different folder in ArcGIS Online but I checked the iteminfo ID and it matches. Other suggestions said to update the schema with the additional fields on the hosted feature layer on ArcGIS Online and then try to republish the form from Connect. I do not have the option to add fields this way despite being the administrator. I'm not sure why. Perhaps because there is a join?
Any help would be greatly appreciated. Thanks in advance.
