I would like to resize the esri popup when maxmized to a smaller size. I have not been able to do it using the chrome inspector. Any suggestions?
Brandon
https://community.esri.com/groups/web-appbuilder-custom-themes?sr=search&searchId=4671319c-5238-4b92-9085-eec173be99eb&searchIndex=5
You can do it with the following JavaScript
<SPAN class="keyword token">var</SPAN> popup <SPAN class="operator token">=</SPAN> map<SPAN class="punctuation token">.</SPAN>infoWindow<SPAN class="punctuation token">;</SPAN> <SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN>popup<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"maximize"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> popup<SPAN class="punctuation token">.</SPAN><SPAN class="token function">resize</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="number token">300</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">300</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
You may also be able to get it to work with css but it might be a bit fiddly due to the different sections of the popup (sizer, title etc).
Thanks. I will try that js way.
Probably but it'll take some playing around with the css this is something that is much simpler with JavaScript.
Anyway to do this with css?
