Ik heb geprobeerd het script Create Drainage Line Structures van Arc Hydro te draaien in ArcGIS Pro en ik kreeg de volgende melding: "Running script CreateDrainageLineStructures...(‘line 2263’, ‘C:\\Program Files\\ArcGIS\\ArcHydroPro\\Scripts\\ArcHydro\\createdrainagelinestructures.py’, ‘RuntimeError: Object: Fout bij het ophalen van parameter als tekst’)".<\/P>
<\/P>
Wat moet er gedaan worden? <\/P>
Alvast bedankt<\/P><\/DIV><\/DIV><\/BODY><\/HTML>
The underlying code was updated and the UI is missing one parameter (EditPoint). This is fixed in the latest version:
http://downloads.esri.com/archydro/ArcHydro/Setup/Pro/ArcHydroPro2.0.8/
Christine Dartiguenave
Esri Water Resources Team
Thank you very much. That subroutine works. Now I am going to verify the whole procedure for the same basin so I could be sure that all the nessecary features have been populated as they should. Thank you again
