If I want to crop a raster to fit within a polygon from another set of data, is this possible, and what tools would I use? Pair clip, union, or join? Thank you!
In ArcGIS Pro, raster datasets can be used with the Clip tool to extract a portion of one raster dataset using the extent of another dataset (such as a polygon feature). This is similar to the Pairwise Clip function in ArcMap. Ensure that the datasets are in same projection.
Hi @FaithLesuer
You can use Clip Raster or Extract By Mask to accomplish this. Keep in mind Extract By Mask requires the Spatial Analyst extension. Take care!
