Recently upgraded from ArcGIS Pro 3.0.3 to ArcGIS Pro 3.3.0. Has Spyder IDE been removed from the Package Manager? I no longer see it as an option to Install in my cloned environment.
conda install
make sure you have a cloned environment active, or you will have to do a 'pip' install into the arcgispro-py3 environment
Dan:
Currently Spyder is not available from Pro's package manager GUI?
The package manager list is out of date and is showing packages for 3.9. Esri is aware of it and I only discovered it in the last 2 days of Beta 3.3. They indicated that it would be updated in the first update for 3.3. In the interim, use conda. If it is in the esri anaconda site (as I have shown) packages can be installed using conda into a clone of the arcgispro-py3 environment. I can confirm this. I can also confirm that you can pip install anything anywhere as long as you know what you might break and what won't matter if you do break it
Hi Dan,
I could not install the Spyder in the cloned environment using the conda install as shown above. It shows:
Your installed version is: not available
Note that strict channel priority may have removed packages required for satisfiability.
What could have been the reason behind this difficulty?
Thank you,
Bijan Gurung
KSU
Have you made any progress on this? I am still unable to install spyder in the latest version of arcpro (3.3.0). Let me know if you found a work around.
I am also having this issue. I have tried installing the current Spyder and Spyder 5.4 and using conda and pip with a cloned environment. I get the following message upon starting Spyder. When I try to install those dependencies, it says they are already present in the version described.
I am also getting this after installing Pro 3.3 on an Azure VM and then pip install Spyder. When I open Spyder, i get the same message and after getting to a point of reverting to those versions, Spyder ends up not loading anymore. Thinking about installing Pro 3.2 or 3.1 as a workaround.
I ended up installing an older version of spyder, I think it was
pip install spyder==5.2.2
