We are a state-owned public utility, and our line crews perform a ground inspection of our transmission lines/poles each year. We use Field Maps and Survey 123 to collect data with the ground inspections. However, we also perform one or two air patrols via helicopters and are looking to incorporate Quick Capture to record any high-level issues they may encounter on the line.
The issue we are having is when you click a button to place an issue over a corridor with multiple transmission lines; how do you assign it to the correct line/circuit? If there are three lines side by side and they are flying over them with one flight. They see pole top rot and click the button to record pole top....how does it assign it to the correct line / structure? We are trying to make this as fast as possible ie) quick capture.
