import arcpy mxd = arcpy.mapping.MapDocument(r"C:\Project\Project.mxd") df = arcpy.mapping.ListDataFrames(mxd)[0] # first data frame lyrs = arcpy.mapping.ListLayers(mxd, "" , df) fixLayers = ["Test1 polygon","Test2 polygon"] newParcel = 5 for lyr in lyrs: if lyr.name in fixLayers: lyr.definitionQuery = "parcel_no = {0}".format(newParcel) arcpy.RefreshActiveView() del mxd # release the object (the map will not be deleted)
import arcpy import pythonaddins class ComboBoxClass1(object): """Implementation for Query_addin.combobox (ComboBox)""" def __init__(self): self.items = ['"parcel_no" = 1', '"parcel_no" = 2', '"parcel_no" = 3', '"parcel_no" = 4', '"parcel_no" = 5'] self.editable = False self.enabled = True self.dropdownWidth = 'WWWWWWWWWW' self.width = 'WWWWWWWWWW' def onSelChange(self, selection): self.mxd = arcpy.mapping.MapDocument("CURRENT") for lyr in arcpy.mapping.ListLayers(self.mxd): if lyr.name.lower() == "parcels1": lyr.definitionQuery = selection if lyr.name.lower() == "parcels2": lyr.definitionQuery = selection if lyr.name.lower() == "parcels3": lyr.definitionQuery = selection arcpy.RefreshTOC() arcpy.RefreshActiveView()
