public class MyFlareClusterer : FlareClusterer { protected override Graphic OnCreateGraphic(GraphicCollection cluster, ESRI.ArcGIS.Client.Geometry.MapPoint point, int maxClusterCount) { if (cluster != null) { if (cluster.Any(g => g.Selected)) { var graphics = new GraphicCollection(cluster.Where(g => g.Selected)); return base.OnCreateGraphic(graphics, point, maxClusterCount); } else { foreach (var g in cluster) return g; } } return null; } }
private void Editor_EditCompleted(object sender, Editor.EditEventArgs e) { if(e.Action == Editor.EditAction.Select) { var l = MyMap.Layers["CensusDemographics"] as FeatureLayer; l.Clusterer.ClusterGraphicsAsync(l.Graphics, MyMap.Resolution); } }
<esri:FeatureLayer.Clusterer> <local:MyFlareClusterer FlareBackground="Yellow" FlareForeground="#99000000" MaximumFlareCount="20" Radius="10" Gradient="{StaticResource BlueGradient}" /> </esri:FeatureLayer.Clusterer>
<LinearGradientBrush x:Key="BlueGradient" MappingMode="RelativeToBoundingBox" > <GradientStop Color="#990011FF" Offset="0"/> <GradientStop Color="#990055FF" Offset="0.25"/> <GradientStop Color="#990099FF" Offset="0.5"/> <GradientStop Color="#9900CCFF" Offset="0.75"/> <GradientStop Color="#9900FFFF" Offset="1"/> </LinearGradientBrush>
You can create your own FlareClusterer and override OnCreateGraphic().You can try the following code: public class MyFlareClusterer : FlareClusterer { protected override Graphic OnCreateGraphic(GraphicCollection cluster, ESRI.ArcGIS.Client.Geometry.MapPoint point, int maxClusterCount) { if (cluster != null) { if (cluster.Any(g => g.Selected)) { var graphics = new GraphicCollection(cluster.Where(g => g.Selected)); return base.OnCreateGraphic(graphics, point, maxClusterCount); } else { foreach (var g in cluster) return g; } } return null; } } I'm not sure if you wanted to refresh the cluster when selection is changed, but if you are using Editor. You can trigger clustering by subscribing to EditCompleted event. private void Editor_EditCompleted(object sender, Editor.EditEventArgs e) { if(e.Action == Editor.EditAction.Select) { var l = MyMap.Layers["CensusDemographics"] as FeatureLayer; l.Clusterer.ClusterGraphicsAsync(l.Graphics, MyMap.Resolution); } } You can look at tweak this SDK sample: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#FeatureLayerSelection. Remove the ArcGISDynamicLayer, change FeatureLayer.Mode to OnDemand, remove the "Renderer="{StaticResource YellowMarkerRenderer}"" and add the following: <esri:FeatureLayer.Clusterer> <local:MyFlareClusterer FlareBackground="Yellow" FlareForeground="#99000000" MaximumFlareCount="20" Radius="10" Gradient="{StaticResource BlueGradient}" /> </esri:FeatureLayer.Clusterer> Under Resources, you can set your gradient. <LinearGradientBrush x:Key="BlueGradient" MappingMode="RelativeToBoundingBox" > <GradientStop Color="#990011FF" Offset="0"/> <GradientStop Color="#990055FF" Offset="0.25"/> <GradientStop Color="#990099FF" Offset="0.5"/> <GradientStop Color="#9900CCFF" Offset="0.75"/> <GradientStop Color="#9900FFFF" Offset="1"/> </LinearGradientBrush>
return new Graphic();
