When you are exporting a map or a layout, there are multiple options that remain saved after closing the project. If you add a Default button at the bottom, you can go back to the original settings if you are not sure what you change the last time.
Hi! This sounds similar to export presets, which are already available in ArcGIS Pro. Have you been able to use them in your workflows?
@AubriOtis Presets are useful but having a "Default" button in the Export Map/Layout window will be handy to have to quickly get back to OOB state after messing around for a specific purpose or chasing a bug feature.
You have all these file types:
but only these default presets (in the ribbon, in a completely different location from where you likely are when using an Export shortcut in the QAT or Cool Tools).
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
