And as an additional tip when it comes to extracting stream lines from dem's...I always create a curvature surface and use that as a weighting into the flow accumulation step.Because of the math of the curvature function, upwardly concave areas (like a stream) are negative,so invert the curvature output first, (X -1) so that +ve values are associated with upwardly concave areasand -ve values indicate the top of the hill (for example).This idea comes from a paper by Tarboten & Ames from about 1992.Otherwise follow the steps in the hydrology section of the help files as suggested by Jim.Cheers,Neil
