Hi
I have change the polygon with make the line around and the finale when i do save they dont make the new change and do the original polygon I want to save the last change why can help someone for more attach the fig
Hi - if you are editing in Pro, you may need to click the 'Finish' button.
Hi David
How can make obstructionldSurface_MP in Aacgis Aviation can you help with one example
Hi Altin,
I have previously posted a video to create the aviation Airports geodatabase. Using this tool will create the ObstructionIdSurface_MP feature class inside the Airspace feature dataset.
Video Link : 6072
Once you have that Airports geodatabase, you can populate the RunwayCenterline feature class and then use the ICAO Annex 14 tool to create the surfaces. There is a video on that here:
Video Link : 6408
These should help
David
Thnx for your email this video are for arcgis pro 2.6 but I have in my compiuter arcgis pro 2.2.0 version I need your help or I can send the point of runway for finish this OLS for i can send the figure version of arcgis pro 2.2.0
I need your help I have done OLS Annex 15 and I need your opinon ... for this ..
I have the problem with tab 1 for more attach file ...{ I thing I ought write runway 18/36 and everythis is ok for this ?}
