I have a query layer that I am able to use in ArcMap to copy and paste features from easily. Select feature, paste to editable layer with same geometry. Easy peasy.
In pro, not so much. I am able to copy/paste from the original base feature class in the enterprise geodatabase, but not any query layers I created from that (also housed in the enterprise geodatabase). The shape/geometry and objectid are the same for the query layers as the original features but whether I create the query layer in pro or create use the version I created for ArcMap I get the same behaviour.
I can select the feature in the map, right click-choose copy. Go to the paste button and select paste special. I get the dialog box and can select my editable layer it should go in and then I get the Failed dialog box. If I do the same workflow with the original feature class (not query layer) it works fine. I can copy/paste from ArcMap using the query layer without any issue. As a side note, I can select, export easily from these query layers in pro.
Is there another work around here? I need the query layers as they enrich the data and help determine which features should be selected/copied.
