I'm trying to run Generate Schema Report. I tested it a month ago and it worked fine. But now, every time I run it, an output error says, "Error 002869 Output file <filename> already exists." No matter what name I give it, it says the file exists. I've never seen such a thing. I'm running ArcGIS Pro 3.3.0 on a desktop PC.
The input is a GDB and I'm trying to output an HTML file. As I said, it worked last month so I don't think the file types are the problem. I tried changing the output location as well, that didn't help.
