Is it possible to set Pro's settings (e.g. default project save location) programmatically (Read: through code)?
Thanks!
Yes, you I believe you can do this using the workflow described in this Esri Technical Support document. Not necessarily Python code but there is code involved in the user.config file.
This is a great start! The other setting I'd look to look for is changing the default Package unpacking location. I don't seem to be able to find it in that config file; is there another place I should look?
Yes, in ArcGIS Pro itself, go the Project->Options->Application group->Share and Download tab and you see many options for Staging, Unpacking of packages, templates, files and offline maps. There is a radio button you can click "Ask where to save before unpacking" that you can set too. If you accept application defaults, they always go to your C:\Users\user_profile\Documents\ArcGIS Pro\Packages directory or others seen in this pane.
Yes, I'm hoping to do this without having to open Pro itself so I can apply these settings for multiple users. Is there a file outside of Pro that I can mess with to make this happen?
