I need a Widget with the ability to view metadata associated with each layer in the table of contents or layer list. Is a Metadata widget available in ArcGIS Experience Builder? If not is there anything in the Pipeline or something similar?
If you want to get it into an Experience Builder text box, the easiest option would probably be to embed your metadata into your data. Add a metadata field to your feature layer and copy in the relevant information, then you can use the Dynamic Text options in Experience Builder to retrieve the information.
Thank you @JeffreyThompson2. I was hoping to implement a feature resembling a text popup or a dynamic text display linked to a data or layer connection. This is useful, however.
If you add a Map Layers Widget and turn on the View Layer Details option, it will provide a link to the REST endpoint and all the metadata it provides.
