Hi there,
I am currently try to run some integration/unit tests with the headless pro instance.
I followed the steps described in the guide (https://github.com/Esri/arcgis-pro-sdk/wiki/ProGuide-Regression-Testing) and even tried to replicate the exact same sample, without any success. I also tried to use the Extension30 nuget instead of the dlls directly (https://community.esri.com/t5/arcgis-pro-sdk-questions/any-suggestion-on-setting-up-unit-test-project-to/m-p/1425869#M11504)
The start up process of the headless test client always throws a null pointer exception:
Object reference not set to an instance of an object.
The stack trace implies that it has something to do with the licensing
at ArcGIS.Desktop.Core.Licensing.LicensedApplication.<CheckForLicenseAsync>d__12.MoveNext()
at ArcGIS.Desktop.Core.ProApp.<TestModeInitialize>d__15.MoveNext()
at GetSymbolSwatchTests.TestEnvironment.<StartApplication>d__2.MoveNext() in C:\Daten\repos\sandbox\GetSymbolWatchTests\TestEnvironment.cs:line 68
I got an ArcGIS Pro 3.3 installation on my host with a valid concurrent use license fetched from a server. Are there any requirements to the licensing level? I also completely reinstalled the ArcGIS Pro installation without any effect. The sample project which I used is attached (sandbox.zip).
Any help would be appreciated!
