out of curiosity, do you have SSL Certificate installed?check "Determining whether a SSL certificate is installed" to see if it's installed or nothttp://webhelp.esri.com/arcgisserver/9.3/dotnet/index.htm#securing_internet_conn.htm
Hey, Having problems accessing secure services thru SSL enabled site https://<arcserver>:6443/arcgis/rest/servicesin JavaScript API and arcgis.com, i get the message: "Unable to access the authentication service".I dint had this problem before SSL was enable.I am using Identify manager and ArcServer 10.1.Flex viewer,ArcExplorer,ArcMap has no problem with secure servicesThanks,Laurynas Gedminas
Have you resolved this yet? I am having the same exact issue. SSL is set, Roles and Users are ok. I can test this through the REST services login page. But the IdentityManager widget gives me a "unable to access the authentication service". when trying to access from a web application.
