I used ArcGIS runtime SDK for iOS and get the access token and the refresh token. I want to know the expiration time of the refresh token. Does anyone know this?
You can use the AGSOAuthConfiguration refreshTokenExpirationInterval property which is defined as: "
The requested expiration interval (in minutes) for the refreshToken generated by the
OAuth request. The max interval can be overridden by the portal administrator.
NOTE: For a permanent refreshToken (if the portal supports it), use -1.
If that doesn't answer your question, can you provide the following information?
- ArcGIS Runtime SDK for iOS version number (100.4, 100.3, etc)
- How are you getting the refresh Token?
- What kind of authentication are you using.
Mark
Thank you Mark! You mean I can set the time in my code like below, and this means I don't need to acquire refresh token anymore?
config.refreshTokenExpirationInterval = -1
Correct. If the refresh token is set to -1, then the SDK will handle refreshing the token so you don't have to. ArcGIS Online and Portal version > 1.6 support this functionality. If you're not using AGOL and have an older Portal, then the refreshTokenExpirationInterval is not supported.
Let me know if you have any more questions,
