Hey There!I'm starting to build a mobile app for Flex to use with PlayBook. I am running in to the same issues where I can't use the esri:Editor and its attribute inspector. Adding the MX source to compiler also fails to successfully build the project if esri:Editor is present. I was going to ask you for some insight or code if you can share and to see how you came up with your solution.Best Regards,Hooman
