Amy, How did you do that in the 1.3 version of the widget?
Aimei, It will help you greatly to post Flex Viewer/Widget question to the Flex Viewer forum and not here on the Flex API forum.There is a lot about this widget that is not compatible with the new API. I believe that I have it updated to achieve what it was originally intended to do in 1.3.Don't forget to click the Mark as answer check on this post and to click the top arrow (promote) as shown below:
I am working on migrate a customized widget from flex API 1.3 to 2.4, this feature label widget will allow users to pick a feature layer first then select the field(s) to be labeled, when click on the selected feature on the map, a callout lable will be displayed on the screen. I have trouble with the mapmouse event --it returns "source not found". Help please if you can! thanksAmy
