Hallo,
Ik vroeg me af of er een manier is om het pop-upvenster zo te configureren dat de afbeelding bovenaan wordt weergegeven, vóór de lijst met velden, en niet onderaan zoals op deze afbeelding.
Bedankt voor je hulp!
You can do so by configuring custom attribute display as explained in the blog post below:
Crafting custom attribute displays in pop-ups | ArcGIS Blog
Configure the image URL before the attributes.
Thanks! I figured it out.
I would like to add photos on on the pop-up from two different fields. If I do it the "normal" way, juts by stacking the field names in the "Display Images" box, I can accomplish it, but the resulting images get lined up in the horizontal way, so I have to click the right arrow to move to the second image. I need to place both images simultaneously on the pop-up, so both can be seen together, one above another. Do you think it is possible?
Examples:
-This is what I have:
-This is what I want (the photo and shoot direction):
P.S. Of course, I can just indicate the shoot directions with the point symbology (as shown here), but there are points where multiple images were taken, while only the top arrow's seen.
Hi Gabriel,
You said you figured it out. Can you share what you did? I've been looking at this for a while and do not see a way to move the image above the attributes.
Mark
