HI
How to query graphiclayer with polygon ?
Thank you.
Chengyi,
Well then you need to do exactly what I mentioned then.
<SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">"esri/geometry/geometryEngine"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>geometryEngine<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> view<SPAN class="punctuation token">.</SPAN>graphics<SPAN class="punctuation token">.</SPAN><SPAN class="token function">forEach</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>gra<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN>geometryEngine<SPAN class="punctuation token">.</SPAN><SPAN class="token function">intersects</SPAN><SPAN class="punctuation token">(</SPAN>gra<SPAN class="punctuation token">,</SPAN> userDrawnGraphic<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">/* now do something */</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Scheitlin
year,this is I needed. thankyou verymuch.
Thank you very much !
Let me explain. Many ploygon are drawn on the graphic when the map is initialized,then I want to draw a new ploygon to search the old ploygon with 4.5 arcgis api for javascript . How to do?
To query a graphics layer you have to loop through the layers graphics and perform your operation on each graphic.
You can use GeometryEngine methods like intersects:
https://developers.arcgis.com/javascript/3/jsapi/esri.geometry.geometryengine-amd.html#intersects
Or if the geometry you want to check is a point geometry, to check if it is inside a polygon then you can use Polygon.contains
https://developers.arcgis.com/javascript/3/jsapi/polygon-amd.html#contains
