Why does my code work in arcgis notebooks but when I run it from a tool box it does not preform every function?
Specifically, the below code block calculates X and Y, then checks for duplicate records and throws and error if it finds any. Then it will inserts the calculated rows into the master file. Then creates a definition query so only the added shapes are shown. Then it updates the shape with the X and Y calculated earlier of the inserted rows based on a unique identifier. It works as intended when run in notebooks. However, when I export to a .py and put it in a tool box as a script it only adds the last row and instead of updating the shape of added records it updates the shape of all records in the file which are set to null as they are calculated at the end of the script(not shown).
Why...
P.S. I have tunnel vision and cannot see the issue
edit: change lines 4 - 9 to remove a while statement
#Updates attribute table and inserts PI with multiple parcels into master file
#Gets array of layer names
lyrlist = MP.listLayers()
lyrname = []
for l in lyrlist:
lyrname.append(l.name)
if "Multiple_Parcel_PIs" in lyrname:
MultiParcel = MP.listLayers("Multiple_Parcel_PIs")[0] #create object for Multiple PI Layer
MultiParcel.updateDefinitionQueries(None) #clears definition queries
MTotal = int(str(arcpy.management.GetCount(MultiParcel))) #Get total count of features
PreGTotal = int(str(arcpy.management.GetCount(Geocode)))
#Calculate Feature Geometry State Plane
arcpy.management.CalculateGeometryAttributes(
in_features = MultiParcel,
geometry_property = "X_Coordinate POINT_X;Y_Coordinate POINT_Y",
length_unit = "",
area_unit = "",
coordinate_system = 'PROJCS["NAD_1983_2011_StatePlane_New_Jersey_FIPS_2900_Ft_US",GEOGCS["GCS_NAD_1983_2011",DATUM["D_NAD_1983_2011",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",492125.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-74.5],PARAMETER["Scale_Factor",0.9999],PARAMETER["Latitude_Of_Origin",38.83333333333334],UNIT["Foot_US",0.3048006096012192]],VERTCS["NAVD88_height_(ftUS)",VDATUM["North_American_Vertical_Datum_1988"],PARAMETER["Vertical_Shift",0.0],PARAMETER["Direction",1.0],UNIT["Foot_US",0.3048006096012192]]',
coordinate_format = "SAME_AS_INPUT"
arcpy.SetProgressorLabel("Combining Shapefiles") #Changes tool progress label
arcpy.SetProgressorPosition(1)
#Hides features that were unable to be verified
MultiParcel.definitionQuery = "Locational_Comments IS NOT NULL"
#Updates locations quality to reviewed and verified in GIS
upcursor = arcpy.da.UpdateCursor(MultiParcel, "location_quality_type_code")
for row in upcursor:
row = [60]
upcursor.updateRow(row)
MultiParcel.updateDefinitionQueries(None)#Clears all definition queries
MultiParcelList = [] #creates empty list for tracking PIs that repeat
PILIST = [] #creates empty list for tracking PIs
now = datetime.datetime.now() #gets time loop started
Mcursor = arcpy.da.SearchCursor(MultiParcel, ["USER_pi_id"]) #gets attribute information
Marray = Mcursor._as_narray() #turns cursor into array
i = 0
while i < len(Marray):
PI = Marray[t][0] #gets PI from array
if PI not in PILIST:
PILIST.append(PI) #appends PI to list
arcpy.management.SelectLayerByAttribute(MultiParcel, where_clause = "USER_pi_id = " + "'" + str(PI) + "'") #Selects features by unique pi id in
count = arcpy.management.GetCount(MultiParcel) #Gets count of selected features
if int(str(count)) > 1 and PI not in MultiParcelList: #checks if multiple records are selected
MultiParcelList.append(PI) #adds PI to list if multiple records are selected
arcpy.AddWarning("PI ID: " + str(PI) + ", has multiple parcels.") #adds warning
i += 1 #adds 1 to iterable varaible
arcpy.SetProgressorPosition(25)#Sets progress bar positionto 25/100
if MultiParcelList:
MultiParcelTuple = tuple(MultiParcelList) #turns list into tuple
MultiParcel.definitionQuery = "USER_pi_id NOT IN " + str(MultiParcelTuple)
arcpy.ExecuteError("Multiple PIs were detected, please correct issue in Multiple_Parcel_PI layer and run again.")
MP.clearSelection() #clears selection in map
cursor = arcpy.da.SearchCursor(MultiParcel, fields) #gets all attributes
array = cursor._as_narray() #turns it into an array
#Add PIs from Multi Parcel PI layer to new dataset
incursor = arcpy.da.InsertCursor(Geocode, fields, None, False) #creates insert cursor
edit.startEditing(False, False) #starts edit session
for row in array: #loops through array
arcpy.AddMessage(str(row))
incursor.insertRow(row) #adds row to Geocode layer
edit.stopEditing(True) #stops edit session
del incursor #deletes insert cursor
PITuple = tuple(PILIST) #turns array into tuple
arcpy.AddMessage(str(PITuple))
Geocode.definitionQuery = "USER_pi_id in" + str(PITuple) #Creates new definition query
break
Gcursor = arcpy.da.SearchCursor(Geocode, ["USER_pi_id", "X_Coordinate", "Y_Coordinate"]) #Creates search cursor for added PIs
Garray = Gcursor._as_narray() #turns it into array
print(len(Garray))
arcpy.SetProgressorPosition(50) #updates progress bar
#Loop through added PIs and updates their shape position all import with 0 X and 0 Y
i = 0
while i < len(Garray):
pi = Garray[p][0] #gets PI from Garray
east = Garray[p][1] #gets X from Garray
north = Garray[p][2] #gets Y from Garray
point = arcpy.Point(east, north) #makes an arcpy point
arcpy.management.SelectLayerByAttribute(Geocode, where_clause = "USER_pi_id = " + "'" + str(pi) + "'") #selects by PI
upcursor = arcpy.da.UpdateCursor(Geocode, ["SHAPE@"]) #Creates update cursor for selected record
for row in upcursor: #updates selected records shape
row = [point]
i += 1
#Deletes created cursors
del Gcursor
del Garray
del Mcursor
del Marray
del cursor
del array
Geocode.updateDefinitionQueries(None) #Clears definition queries
arcpy.SetProgressorPosition(99) #updates progress bar
end = datetime.datetime.now() #gets time loop ended
elapsed = end - now #does math for run time
arcpy.AddMessage("Combining shapefiles elapse time: " + str(elapsed)) #adds arcpy message
NewTotal = PreGTotal + MTotal
if NewTotal != GTotal:
arcpy.ExecuteError("Contact CSRR GIS Team, combining MultiParcel to Geocode failed.")
