Hi can someone shed some light on why only some of my attributes show up as options for creating an infographic chart? all of my attribute fields are numeric so I'm not sure why some are missing.
Thanks!
What is the source of the layer? Can you share your map publicly? It's possible that a field you believe to be numeric is not. For example, I've seen cases where someone imports a CSV where a numeric field contains a string, and thus the field is defined as a string field when a hosted feature layer is created from it.
Mike
Thanks Mike,
One of my fields did contain a string I was able to fix the issue
