The 3.3 release of untools contains the fixes from untools 3.2.0. For more information, see the 3.2 release notes.
untools 3.3.4 - June 2025
untools 3.3.3.1 - December 2024
untools 3.3.3 - November 2024
untools 3.3.2 - August 2024
untools 3.3.1 - July 2024
untools 3.3.0 - May 2024
Add support for Utility Network version 7
Apply Asset Package
Upgrade Asset Package
Miscellaneous
@gpgisandsky I've not been able to reproduce that behavior, but I believe it should be resolved with 3.3.4
hi,
im on pro 3.3.5 + un tools 3.3.3.1. When I try to apply assetpackage to file geodb (empty un v7) the following error appears:
The issue is related to how the CSV was generated by the tool during execution (AP_Workspace0\csv\association001.csv). The tool creates a CSV file using a comma as the separator instead of a semicolon, which is what the import tool expects. Is there a parameter in PRO "or elsewhere that can be changed?
@TomEriksencan you try from an non-elevated python command prompt? Internally, the tool is writing to the registry so that might explain it.
I am not sure what else could be the difference from in-app vs standalone python.
Hi @PaulLeBlanc1 . I'm having issues using untools 3.3.3.1 to stage a utility network with the correct UN version. I'm trying to create a UNv6. Works fine when running inside of ArcGIS Pro, but when running as a standalone python script it creats a UNv7 even though the logging seems to be correct.I have tested running StageUtilityNetwork as a GPtool, as a notebook and in the python window in ArcGIS Pro 3.3.5 wich results in the correct UN version. But as a standalone it always creates an UNv7.
@PaulLeBlanc1 I was hoping you could maybe answer a question on had on the Upgrade Asset Package Tool. I have a post in UN section I linked below. Trying to figure out when the upgrade tool would need to be run and what impact it has on the asset pack.
https://community.esri.com/t5/arcgis-utility-network-questions/question-on-upgrade-asset-package-tool-utility/m-p/1495091
Thanks!
@PaulLeBlanc1 Exactly!The table is there - it is present and the name is correct (in the Asset Package).Even this, the tool crashed
@IvanDImitrovI am not aware of any issues in this area. This is valid arcade.
FeatureSetByName($datastore, 'LineTypeLib', ['*'], false)
If there isn't a table called LineTypeLib then the runtime error is expected.
Hi, Paul! Thanks for the good news!Did the team updated the annoying error, that 3.2.- give:
ArcGIS Pro 3.2.2.49743untools 3.2.0Executing from ArcGIS Pro, 0 map(s), activeMap = FalseParallel processing enabled: 6
C:\UN_V2_2\ZERO\AP_Workspace0\xml\ElectricLine_2_EditorTracking-AttributeRules.xml:255ERROR 002717: Invalid Arcade expression, Arcade error: Table not found LineTypeLib, Script line: 1 [LineTypeLib]WARNING 000952: Failed to execute (AddAttributeRule).C:\UN_V2_2\ZERO\AP_Workspace0\xml\ElectricLine_2_EditorTracking-AttributeRules.xml:288ERROR 002717: Invalid Arcade expression, Arcade error: Table not found LineTypeLib, Script line: 1 [LineTypeLib]WARNING 000952: Failed to execute (AddAttributeRule).C:\UN_V2_2\ZERO\AP_Workspace0\xml\ElectricLine_2_EditorTracking-AttributeRules.xml:321ERROR 002717: Invalid Arcade expression, Arcade error: Table not found LineTypeLib, Script line: 2 [LineTypeLib]WARNING 000952: Failed to execute (AddAttributeRule).C:\UN_V2_2\ZERO\AP_Workspace0\xml\ElectricLine_2_EditorTracking-AttributeRules.xml:364ERROR 002717: Invalid Arcade expression, Arcade error: Table not found LineTypeLib, Script line: 2 [LineTypeLib]WARNING 000952: Failed to execute (AddAttributeRule).Failed script Apply Asset Package...Failed to execute (AssetPackageToUtilityNetwork).I think the XML is not correctly build here:
