You will need to create your own static methods to change these--At least I have not seen any in the runtimes ??
though its pretty easy -- here is a utility class that I created for c# should be pretty easy to convert to Objective C and Java
so the key is the MapPoint
public static string ddToDms(double coordinate, bool dm) { var neg = coordinate < 0d; var dms = string.Empty; coordinate = Math.Abs(coordinate); var d = Math.Floor(coordinate); coordinate -= d; coordinate *= 60; var m = Math.Floor(coordinate); coordinate -= m; coordinate *= 60; var s = Math.Round(coordinate); char pad; char.TryParse("0", out pad); var dd = d.ToString(); var mm = m.ToString().PadLeft(2, pad); var ss = s.ToString().PadLeft(2, pad); if (!dm) { dms = string.Format("{0}°{1}'{2}\"", dd, mm, ss); } else { var pMin = (s / 60) + m; var msFormat = string.Format("{0:0.####}", pMin); dms = string.Format("{0}°{1}'", dd, msFormat); }
if (neg) { dms = "-" + dms; } return dms
the bool is for Decimal minurtes if true will give you the Decimal Minutes
this is the static method that I created for C# but using the Java you would be able to call String.Split() returns an array and for Objective C
send the message [@string ComponentsSeperatedByString:@this is the char to separate by] to a NSArray *var
P.S. thanks Chris Bradberry I stole a lot of the original logic from him
