I need to overwrite the feature service for an existing layer to add domains and a related table. Assuming I carry over all the records and maintain the same globalid, will users still be able to resend records from their Sent box?
I ended up testing this and yes, you can overwrite the feature service and still resend records as long as you maintain the same globalid's.
I do not think you will be able to save the globalid. There is a check box for it in Pro but I heard it does not usually work. I would test this first by making a copy.
Yeah, I ran into that issue with feature geodatabases. You can get around the issue by using a mobile geodatabase, which will maintain globalid's. I just copy and pasted data into a mobile gdb before making changes. The globalid's are all the same after publishing a test service.
I'm working in a test survey, but testing the resent feature is enough of a headache I thought I would ask first.
