I have created one scene document (sxd) having borehole data . In the document I have set some settings such as extrustion etc., My requirement is to convert the sxd to 3D PDF format only.
Kindly suggest me the solution.
Regards,K.Jayakumar
So from my link, it isn't even available in 10.5.1. If you don't want to vote an idea up, what do you want to do?
Not able to create VRML in ArcScene 10.3.1 it is creating 0kb and get stuck. I have tried old version also , but the process stopped in between. It seems there is an issue in Export -> 3D in arcscene. Same issue faced by some other users also Arscene 10.3.1 blank vrml and exception thrown in destructor
Check this out (require Adobe Acrobat Pro Extended Edition)
3D PDF Generation - ArcGIS Blog
There are some alternatives listed here: export to 3D pdf and you should upvote this idea: https://community.esri.com/ideas/12252
that option isn't listed as a possibility directly
http://desktop.arcgis.com/en/arcmap/latest/extensions/3d-analyst/about-exporting-a-3d-document.htm
