Hi
I have a a feature layer with many fields in Experience Builder.
I would like the user to be able to select the field that the map symbology will be based on, a bit like changing Symbology field in ArcGIS Pro. And I need the symbology type to be Graduated.
Is there a widget that can do this or would it need to be a custom solution? If custom, can you point me in the right direction.
Kind regards
