Hi everyone,
I have following problem regarding my companies Microsoft SQL Server 2019. We are currently considering using ArcGIS Pro to access our Microsoft SQL Server. So far we are already using MapInfo and QGIS to access the database. With both programmes, we can process the data with several users at the same time, which is very important for our workflow.
The problem I am now facing is that I can establish a connection to the server, view the data in ArcGIS Pro and also carry out queries. However, I cannot edit the datasets, e.g. digitise new objects or similar. ArcGIS Pro says that the datasets are only available as "Read Only" and therefore cannot be edited. The data is displayed with "dbo.Filename" with the file type database feature class.
I have tried to find a solution using the online documentation, but I can find several possible reasons for this. Basically, it would be important that the database can be accessed with ArcGIS Pro as well as QGIS and MapInfo and that changes can be made.
Is there a solution for this?
Thank you for your help in advance!
Georg
