Hi all,
I want to get screenPoints of polyline (maybe array of points, no problem). For point features i use code:
projection.load().then(function () {
let screenPoint = view.toScreen(feature.geometry);console.log(screenPoint.x, screenPoint.y);
A polyLine is just a series of points inside a 'paths' array.You can just use a javascript .forEach() to go through each point in the array create a new Point from the coordinates and to output the screenPoint.Note polyLines can have multiple line segments so you'll want to check each line segment as well.//pseduoCode exampleconst polyLine = feature.geometry // Your polyLine feature. polyLine.paths.forEach((path) => { //for each line segment inside your polyLinepath.forEach((coordinates) => { //for each coordinate in your line segmentconst newPoint = new Point(...) //create a new Point using the path coordinateslet screenPoint = view.toScreen(newPoint );console.log(screenPoint.x, screenPoint.y);})})
Hi @JamesIng, thank you. your answer is what i was looking for
