Hi there,
I've been attempting to use EBK 3D to generate subsurface temperature maps for my dissertation. I have ~ 400,000 surface point temperatures derived from a raster that was sampled to the resolution of the cell size (500 meters) and I have ~ 70,000 subsurface temperatures derived from wells. Yes, that's quite the difference in sample populations and the overall histogram looks double peaked. A secondary problem is that there is a known subsurface thermal anomaly, so the subsurface temperature population is itself double peaked.
The purpose of the generated maps is to outline any thermal anomalies, and from my initial results it appears that there are more than just the big one I mentioned, but I'm concerned that the other anomalies are just manifestations of the parameters I've chosen for the model. The model parameters I'm running are below.
* Transformation type: None (If a transformation is used the model looks very jagged / not geological)
* Semivariogram model type: K-Bessel
* Subset size: 20 (smallest to preserve small-scale variation / anomalies)
* Overlap factor: 1
* Number of simulations: 1000
* Elevation inflection factor: Esri Default
* Trend Removal: None (If trend removal is used the model looks very jagged / not geological)
* Eight Sector search neighborhood with 5 neighbors per sector both Max and Min (trying to balance the number of neighbors with preserving local anomalies)
* Search Neighborhood size: Esri Default
From the trainings it seems that I should be choosing an Empirical transformation (since I have basically a three peaked histogram) with first order trend removal (temperature increases with depth) but when I use those parameters the model looks terrible. I guess my concern is is the terrible looking model more correct? Am I choosing the "right" parameters? Are my subsets too small for the number of neighbors I want? Am I choosing the "right" 3D search neighborhood? Should I manually change elevation inflation factor? Again, I'm trying to preserve local variation as much as I can. I also don't understand if first order trends are removed from the population as a whole or are they removed within the search neighborhood.
Sorry if this was a little rambling and for having so many questions. I'm also likely to be asked about some of this for my dissertation defense as well and some of the parameters are a little bit like a black box to me.
