Hello! Is there a way to have a survey only show a question once the survey has been submitted? I have the survey embedded in a dashboard for editing and don't want certain questions to be visible to the survey participants, just to admin staff.
You could try a formula of today() greater than created_date in the relevant field. That might do it.
--gary
Thank you for the suggestion! I'm not quite sure how to implement that though. How do I reference the creation date within the xls? I see there is a field 'CreationDate' in my survey data that is populated with data, but when I try to reference it using ${CreationDate} within my form, it indicates that there is no such survey element.
Any further suggestions?
Edit: Got it! My solution was to create 3 fields and use a relevant calculation: ${createddate} < ${now}
Setting the 'now' question to read-only causes it to automatically be recalculated upon opening the form for editing and results on the previously hidden questions showing up.
