I am trying to embed a secured arcgis dashboard in my EXB application(dev edition),I am passing in the below url to the embed widget. But the authentication is not shared and the dashboard is asking for login again.
https://myarcgisorgportal.com/portal/apps/dashboards/123803221e8eb45148c2ef41f032740xy?arcgis-auth-o...
Any help is much appreciated. Thanks!
@Saxina wrote:When I tested this case (ExB app and embedded app are from same self-domain organization - not using the extra queryparams), the authentication is shared and there is no 2nd login prompt. But for cross domain the authentication is not shared eventhough I used "arcgis-auth-origin" and "arcgis-auth-portal" params.
@Saxina Thanks for your testing and feedback. Unfortunately I still not reproduce the issue you described. If possible, could you describe more about your case?
Hi @Wei_Ying ,
Yes my app is created with dev edition, I am currently testing the development version of my application(https://localhost:3002/).The arcgis org portal(https://myarcgisorgportal.com/ ) and my app portal( https://myappportal.com/ ) are not same domains
The "arcgis-auth-origin" and "arcgis-auth-portal" parameters are used for cases of crossing organizations when the apps' domain is "arcgis.com". If your ExB app and embedded app are from same self-domain organization , you don't need those parameter. Could you have a try by removing the parameters?
hi @Saxina ,
Your EXB app is created with dev edition and deployed to the same domain https://myarcgisorgportal.com/ right?
