I am migrating an Add-In from ArcMap to ArcGIS Pro. I have a file geodatabase with 1 feature dataset with 63 feature classes. I need to search through all feature classes in the feature dataset checking for REACH_GUID IS NULL and return a list of OBJECTIDs for each feature class. It takes 60 seconds in ArcGIS Pro vs 30 seconds in ArcMap. Is there any way to speed this up?
Dim irolFCD As IReadOnlyList(Of FeatureClassDefinition) = cls.gdb.GetDefinitions(Of FeatureClassDefinition)()
For Each fcd As FeatureClassDefinition In irolFCD
Dim layerName As String = fcd.GetName()
If fcd.FindField("Reach_Guid") <> -1 Then
Dim tblLayer As Table = cls.gdb.OpenDataset(Of Table)(layerName)
Dim qf As QueryFilter = New QueryFilter()
qf.WhereClause = "REACH_GUID IS NULL"
Dim rc As RowCursor = tblLayer.Search(qf, False)
Dim l As List(Of Integer) = New List(Of Integer)
While rc.MoveNext
l.Add(CType(rc.Current("OBJECTID"), Integer))
' Add layerName, OBJECTID to list
End While
If l.Count > 0 Then
dctFC.Add(layerName, l)
End If
End If
