I'm trying to use the Security Advisor at
https://s3.amazonaws.com/ago-security-advisor/index.html#
It looks like it has lost its connection to the CSS.
Everything is messed up and the tool can't be used.
Yigal
I like and use those tools and can see the same issues. I'll report that to the Trust.arcgis.com team to have a look at.
The issue has been reported and the security advisor developer will remedy.
Has this been resolved yet?
Yes, it has been resolved. The old Security Advisor has been replaced by the new one, so if you are using old links you might want to update.
Go to: https://trust.arcgis.com/en/
In the right corner click Launch Security Advisor
Then sign in from the upper right corner:
I just tried the link you kindly sent and I still get nothing from the web page. I can reaech it, and even log in, but when I try to run the analysis toll nothing happens. I tried a different browser and it didn't work that time either.
Let me check again. Which link are you using that seemed to fail?
I opened trust.esri.com and signed in to an ArcGIS Online account in Chrome, Firefox, Edge - all with no issues, all return security advisement about my organization correctly. As far as I can tell, everything is working as it should be.
Hi Bern, I used this link https://trust.arcgis.com/en/ that you previously sent.
Which browser? About all I can think of to try at this point is to ensure your browser cache is cleared, then try again (or try in an incognito/private window).
The "en" is automatically added, you can also try https://trust.arcgis.com but it shouldn't matter.
I had one of our analysts try and he got the same response. Here's a clip of an error. Does it make sense to you? Maybe a firewall issue on our end? Thanks again for your help.
Eric
I'll try that and see what happens. We used EDGE and Chrome.
Having this same issue but on an Enterprise site. Did you have any luck resolving this? I added the new SA URL to the Allowed origins in Portal, but no luck.
I just keep getting a redirect error when I try to log in for enterprise. i have the App registered and have the AppID. I know I am missing something.... 😞
This page has a screen shot mentioning using the "portalURI"
https://www.esri.com/arcgis-blog/products/arcgis-enterprise/administration/security-advisor-extended-to-check-arcgis-enterprise/
Where are the explicit instructions for 10.8.1? 10.9.1?
