Hi,I can confirm that Explorer will turn off Aero themes, but also that it should switch it back when the application closes. The reason for this is for improved performance when working in 3D, and the decision was made to turn this off once at startup while Explorer is running.Mike RuddenESRI
Hi,To provide the best user experience, even in 2D, we would always want to switch to the Basic theme. If you're developing an Add-in for ArcGIS Explorer which is going to be deployed to a wider audience but you do not know in advance what their machine spec will be, then the switch to the Basic theme definitely makes sense.
Having said that - feel free to propose the idea at http://ideas.arcgis.comMike
Hi,Disabling the advanced visual effects is one of the main ways recommended by Microsoft to boost the performance of Windows 7 (see http://windows.microsoft.com/en-US/windows7/Optimize-Windows-7-for-better-performance).To provide the best user experience, even in 2D, we would always want to switch to the Basic theme. If you're developing an Add-in for ArcGIS Explorer which is going to be deployed to a wider audience but you do not know in advance what their machine spec will be, then the switch to the Basic theme definitely makes sense.Having said that - feel free to propose the idea at http://ideas.arcgis.comCheersMike
