Hello everybody,
we currently have the issue that we have to avoid the use of safari services. Our goal is to use the os standard browser for authentication. Its working when the AGSAuthenticationManagerDelegates´s function is called where we handle the authentication flow manually and not with "continueWithDefaultHandling".
func authenticationManager(_ authenticationManager: AGSAuthenticationManager, didReceive challenge: AGSAuthenticationChallenge)
But if the token expires, a popup appears for login which redirects to a SafariViewController for new authentication. Is there a way to not use the SafariViewController and use the os standard browser instead for a new authentication as well? It seems that the callback function mentioned above is not triggered again for re-authentication.
So what triggers the re-authentication to show a popup and use the SafariViewController?
Thank you
