Hi everyone! I am super new to SDK, so there may be an obvious answer. Is there a way for a user to select a point on a map and then that point is buffered a set distance? I'm using Visual Studio 2022, and the ArcGIS Pro Module Add-in (C#).
I've looked at the pro snippets to buffer a MapPoint on the GitHub, but I'm just not connecting the dots on it. I've been able to set it so a user can select a point on the map and it shows the coordinates in a message box, and have an initial message box pop up prompting the user to select a point, I've just been running into issues getting a buffer to work. I've included my code down below, thanks for any advice!
namespace Tester
internal class MapTool1 : MapTool
public MapTool1()
IsSketchTool = true;
SketchType = SketchGeometryType.Point;
SketchOutputMode = SketchOutputMode.Map;
// This happens before the tool is run //
protected override Task OnToolActivateAsync(bool active)
MessageBox.Show(
"Please Select a Point on the Map!"
MapPoint pt = MapPointBuilderEx.CreateMapPoint(1.0, 1.0, SpatialReferences.WGS84);
Geometry ptBuffer = GeometryEngine.Instance.Buffer(pt, 5.0);
Polygon buffer = ptBuffer as Polygon;
return base.OnToolActivateAsync(active);
//This happens when the user clicks and begins to use the tool
protected override Task<bool> OnSketchCompleteAsync(Geometry geometry)
MessageBox.Show(
"North: " + geometry.Extent.YMax.ToString() + "\n" +
"South: " + geometry.Extent.YMin.ToString() + "\n" +
"East: " + geometry.Extent.XMax.ToString() + "\n" +
"West: " + geometry.Extent.XMin.ToString()
MapPoint pt = MapPointBuilderEx.CreateMapPoint(1.0, 1.0, SpatialReference.WGS84);
return base.OnSketchCompleteAsync(geometry);
