I'll check over source when I get home. This could be left over from a limitation I had in my code where our internal locator required a city or zip. I'll see if I can fix that.Thanks for pointing it out.
/** * Will parse the item passed to this class and prepare it for * use with ArcGIS Server geocoder. * @param item * @return */ protected function buildAddressObject(item:Object):Object { var address:String = ""; var city:String = ""; var state:String = ""; var zip:String = ""; var country:String = "USA"; if (_addressField.length > 0) address = item[_addressField]; if (_cityField.length > 0) city = item[_cityField]; if (_stateField.length > 0) _stateField = item[_stateField]; if (_zipField.length > 0) zip = item[_zipField]; if (_countryField.length > 0) country = item[_countryField]; // You may need to modify these fields to work with your // particular locator service return { Address:address, City:city, State:state, Zip:zip, Country:country }; }
Sorry for the delay.I've updated the source code this morning.http://www.arcgis.com/home/item.html?id=c663df2846d04a6b9add92b66c637728You can now define the output Spatial Reference wkid for your Locator service so that it will match your map services.I tested it briefly without issue, but if anything does not work please let me know.Thanks.
