Hi
Is there anything in api 100 that provides similar functionality to AGSDynamicLayer? We have existing code that creates a layer from images that I am trying to port.
thanks
Thank you for your question! Support for dynamic layer capabilities on the AGSArcGISMapImageLayer is coming with our next release, due in late Q2 2017.
You were subclassing AGSDynamicLayer before? If so then the closest thing we have is allowing you to create custom tiled layers. Check out this category:
@interface AGSImageTiledLayer (CustomImageTiledLayer)
Also depending on what you were doing you might be able to use a raster layer instead now.
thanks for replying, is there an example of this anywhere?
I am never geting any calls to tileRequestHandler, probably messed up AGSTileInfo.
If you are not getting calls to your tileRequestHandler, yes, double check your AGSTileInfo and make sure you have created a layer of type AGSImageTiledLayer. There is a AGSServiceImageTiledLayer class has a different handler that is used to provide a URL for a tile.
Here is a some sample code which gets a a default AGSTileInfo and extent from one of the standard base maps, then uses that information to create a custom tiled layer.
override func viewDidLoad() {
super.viewDidLoad()
// Do any additional setup after loading the view.
//This will get the default tileInfo; it passes a completion handler
//which will create the custom layer and add it as a baseLayer to
//a new map.
defaultTileInfoWithCompletion { (tileInfo, fullExtent, error) in
//make sure we have no error and our tileInfo and fullExtent are OK
guard error == nil else { print("defaultTileInfo generated an error: \(error)"); return }
guard let tileInfo = tileInfo else { print("tileInfo is nil"); return }
guard let fullExtent = fullExtent else { print("fullExtent is nil"); return }
//creat the customLayer
let customLayer = AGSImageTiledLayer(tileInfo: tileInfo, fullExtent: fullExtent)
//Set tileRequestHandler, which gets called when the map needs a tile
customLayer.tileRequestHandler = { [weak customLayer] (tileKey: AGSTileKey) in
//In this sample, we're just responding with the data for a blue pushpin; for your own tiles,
//you would use the information in tileKey to return the correct tile data.
let image = UIImage(named: "BluePushpin")
customLayer?.respond(with: tileKey, data: UIImagePNGRepresentation(image!), error: nil)
//create a basemap, adding our customLayer as a baseLayer
let basemap = AGSBasemap()
basemap.baseLayers.add(customLayer)
//create the map and load it. You could also set it on a mapView, which would load it for you.
let map = AGSMap(basemap: basemap)
map.load(completion: { (error) in
guard error == nil else { print("Error loading map: \(error)"); return }
print("Map is loaded!")
self.myMap = map
//This method gets the default tileInfo from a simple basemap
//Because loading the baseLayer is asynchronous, a completion handler
//is provided; the handler will be called when the baseLayer is loaded
//Clients should create a tileInfo object using one of the AGSTileInfo constructors,
//based on your specific tile information.
func defaultTileInfoWithCompletion(_ completion: @escaping (_ tileInfo: AGSTileInfo?, _ fullExtent: AGSEnvelope?, _ error: Error?) -> Void) {
let basemap = AGSBasemap.lightGrayCanvas()
basemap.load { (error) in
guard error == nil else { print("basemap failed to load: \(error)"); return }
if let baseLayer = basemap.baseLayers[0] as? AGSArcGISTiledLayer {
baseLayer.load(completion: { (error) in
if error != nil {
completion(nil, nil, error)
return
let tileInfo = baseLayer.mapServiceInfo?.tileInfo
completion(tileInfo, baseLayer.fullExtent, nil)
Let us know if you're still having problems.
thanks a lot, the example helped
But I'm not sure if AGSImageTiledLayer is going to work for us, we have large hires images that I think will be to slow to resize and section.
AGSDynamicLayer worked really well for these, on Android we are using PictureFillSymbol that worked fairly well. Is PictureFillSymbol going to be added?
MDostal-esristaff thanks its worked for me
