Currently, there is no way to view related records in ArcGIS.com map viewer.Thanks,Mike
Any update on this?
related records are now supported in ArcGIS.com map viewer...
Configure pop-ups—Help | ArcGIS
Mike
You still cannot edit related attributes, correct? Do you know if that will be supported in one of the next releases?
Thanks a lot Mike Minami, I hadn't seen that. How do the relationships work when you open the Feature Service in ArcMap? I've published a feature service to AGOL with relationship classes. It works well from the Web Map. However, when I open it in ArcMap it seems some of the layers show the relationships correctly but others don't. Are the relationships supported in ArcMap?
