ArcGIS Pro 2.9.12; Oracle 18c 10.7.1 EGDB:
Is there a way to view an enterprise geodatabase FC's geoprocessing history in the ArcGIS Pro UI?
Or is a FC's geoprocessing history only available in an exported XML file?
@Bud you can change the Metadata Style to anything except the default Item Description in order to see the geoprocessing history that is stored in the dataset metadata.
https://pro.arcgis.com/en/pro-app/latest/help/metadata/view-and-edit-metadata.htm#ESRI_SECTION1_0FAB123C7C3C4CD49894272A899490ED
If you go to the Analysis tab and in the Geoprocessing group, there is the History command there. Or are you looking for something more specific?
Thanks.
I'm looking for the complete geoprocessing history of a given FC, the equivalent to what I can see in the XML:
That XML geoprocessing history goes all the way back to when the FC was created in ArcMap 9.3.1 (?) in 2011.
Is this what you're looking to do? See image below. Go to the Project tab ->Application->Geoprocessing and check the "Write geoprocessing operations to XML log file"
Does this help if I want to export or view the history of all geoprocesses from an existing project where I did not select that 8 months ago before I realized I would need to comb through my geoprocessing history?
