I've been trying to run the Path Allocation tool with a custom VRMA-VF table to model energy expenditure for travel on foot. The tool will run if I use the built-in vertical factor functions, but hangs indefinitely (most common in ArcGIS 10) or fails with a meaningless error message (most common in ArcGIS 9.3.1) when I use a custom table. I assume I have made an error in formatting the table. The online help (http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//009z000000z9000000.htm) gives an example for building the table, but it is just a copy of the sample table for the horizontal factor. Does vertical factor also need to run from 0 to 180 degrees? If so, to what slope do 0, 90, and 180 correspond?
I just tried to use these VF Table values in Arcmap 10.3 and the PathDistance function is currently broken. Consider using the original GRID command line PathDistance or use the new ArcGIS Pro. I just checked and ToblerAway.txt works as expected in ArcGIS Pro 1.0.
best, Nico
