Frm cim-spec/docs/v3/Overview-Symbols.md at main · Esri/cim-spec (github.com), I can read the number and properties of symbol and symbol layers. However, how to add a symbol or symbol layer of an existing symbolic system in a layer with SDK?
Are you looking to add a new class break to a Unique Value renderer? If so, here is a code snippet:
var layer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(); if (layer == null) return; QueuedTask.Run( () => { var uvr = layer.GetRenderer() as CIMUniqueValueRenderer; if (uvr == null) return; var cimUniqueValueGroup = uvr.Groups[0] as CIMUniqueValueGroup; var classes = cimUniqueValueGroup.Classes; var cimUniqueValueClass = new CIMUniqueValueClass(); cimUniqueValueClass.Label = "New Value"; var lineSymbol = SymbolFactory.Instance.ConstructLineSymbol(ColorFactory.Instance.RedRGB, 2.0, SimpleLineStyle.Solid) ; lineSymbol.UseRealWorldSymbolSizes = false; cimUniqueValueClass.Symbol = lineSymbol.MakeSymbolReference(); #region New value to the class var cimUniqueValues = new List<CIMUniqueValue>(); var cimUniqueValue = new CIMUniqueValue() { FieldValues = new string[] { "New Value" } }; cimUniqueValues.Add(cimUniqueValue); #endregion cimUniqueValueClass.Values = cimUniqueValues.ToArray(); cimUniqueValueClass.Visible = true; var classesList = classes.ToList(); classesList.Add(cimUniqueValueClass); cimUniqueValueGroup.Classes = classesList.ToArray(); uvr.Groups[0] = cimUniqueValueGroup; layer.SetRenderer(uvr); });
Regarding your second question, if you are looking to add a new Symbol layer to an existing symbol, this is the code snippet:
var layer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault( s => s.ShapeType == esriGeometryType.esriGeometryPolyline); QueuedTask.Run( () => { var simpleRenderer = layer.GetRenderer() as CIMSimpleRenderer; var lineSymbol = simpleRenderer.Symbol.Symbol as CIMLineSymbol; if (lineSymbol == null) return; var layers = lineSymbol.SymbolLayers; var solidStroke = SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.RedRGB, 2.0, SimpleLineStyle.Solid); var offSetEffect = new CIMGeometricEffectOffset() { Method = GeometricEffectOffsetMethod.Rounded, Offset = 3, Option = GeometricEffectOffsetOption.Fast }; solidStroke.Effects = new CIMGeometricEffect[] { offSetEffect }; var layersList = layers.ToList(); layersList.Add(solidStroke); lineSymbol.SymbolLayers = layersList.ToArray(); simpleRenderer.Symbol = lineSymbol.MakeSymbolReference(); layer.SetRenderer(simpleRenderer); });
For example, if there is a symbol system represented by a unique value, I programmed a CIMLineSymbol variable. How to add it and generate a new line in this table.
Also, when I programmed a CIMSymbolLayer variable, how to add it to the above table as a new line?
