Is it possible to change the schema that comes across when you deploy the solution, to match the schema I currently. If I cannot, then how can I deploy my existing data to the Backflow Preventer feature class/hosted feature service.
David and I reviewed the schema changes and landed on a workflow of using the solution as inspiration and building out similar products around his own feature services.
Hi David,
It is possible to change the schema that comes with the solution. The join view that shows the last inspection will need to be deleted temporarily to unlock the schema.
Please send me an email: j.smith@esri.com and I can help you with more details based on the changes you need to make.
Thanks,Joel
