Javascript 1.5, ArcGIS Experience Builder 1.13
Hi
I would like to add functionality (buttons?) to my Javascript (REACT) that allows toggling FeatureLayers on/off.
Snippet of my code
import { React, AllWidgetProps } from "jimu-core";
import { JimuMapView, JimuMapViewComponent } from 'jimu-arcgis'
import FeatureLayer from "@arcgis/core/layers/FeatureLayer";
import Graphic from "@arcgis/core/Graphic";
import { Button, Icon } from 'jimu-ui'; // import ui components
const { useRef, useState } = React
export default function Widget (props: AllWidgetProps<any>) {
const [mapView, setMapView] = useState<JimuMapView>()
const fileLayer = useRef<__esri.Layer[]>([])
// Location Points are loaded in fileLayer (there are 3 layers)
// fileLayer is used to to create ringPolys (geometryEngine) which in turn are used to create Graphics (three of them)
const ringGraphics: Graphic[] = []
for (let index = 0; index < ringPolys.length; index++) {
const ringPoly = ringPolys[index];
const ringGraphic = new Graphic({
geometry: ringPoly,
symbol: bufferSymbol,
attributes: {
ObjectId: index,
"name": "Graphic" + index
console.log(ringGraphic)
ringGraphics.push(ringGraphic)
}//end for
// Graphics are used to create FeatureLayers (featLayer)
mapView.view.map.add(featLayer)
return (
<div>
props.useMapWidgetIds &&
props.useMapWidgetIds.length === 1 && (
<JimuMapViewComponent
useMapWidgetId={props.useMapWidgetIds?.[0]}
onActiveViewChange={(jmv: JimuMapView) => {setMapView(jmv)} }
</div>
I'm pretty sure that whatever I get working, it's going to reside in the return function. If easier, I'd be ok with toggling the Graphics instead.
Thanks...
